Nixon The Unit Watch Logo
A
Anonymous Posted on Mar 03, 2014
Watch shuts off when I press the light button. When I press it, the temp only lights off then the rest is gone
I accidentally pressed the light button on my watch and it has gone blank cant see how it can be fixed
Muhammad, take a pen and repeatedly stab the light button 20x,
to un stick button, if this does not do it, change the battery, as it is probably weak.
Mar 06, 2016 • Watches
2helpful
10helpful
2answers
I don't know how to turn off the automatic light feature on my watch
There is a button with an atomic time symbol below the face of the watch. Press and hold this button until you hear a beep and the light will go off. To turn it back on again, just press and hold that same button until you hear a beep and it will come back in automatically when you tilt your watch.
38helpful
2answers
Kenneth Coleman Watch Beeps Every Hour! It Needs to STOP!
think of the top buttons from left to right as A & B and the bottom buttons from left to right as C & D. The way to turn the chime off and on is by holding the C & D Buttons simatainiously and the pressing the B button. This will allow you to turn the Hourly Chime Off and On. When you see the digital chime pattern in the display the chime is on. When no pattern is shown the chime is off. Hope this helps the ton of people who have purchased these watches & either did not have instructions with or lost them. This perticular watch has been annoying the whole household for quite sometime and has now been put to rest..lol
Mar 27, 2009 • Watches
100helpful
4answers
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
246helpful
7answers
GapKids Digital Watch - Need to know how to set
Light button is A
Mode button is B
Start button is C
Reset button is D
Standard Time Adjustment:
1) To set time, date, etc. press button B three times (assuming you start in standard time display mode)
2) Press button D until the area you'd like to change is flashing. (i.e.: minutes, date, day, etc.)
3) Press button C to change. Press once for one unit increment of change. Hold for 3 seconds for speedy advance.
4) Press D again until the next area you'd like to change is flashing.
5) At completion of changes press Button B to resume standard time display mode.
9helpful
Auto light wont turn off.
You need to press & hold the forward button on the right side of the watch for a few seconds. That will turn off the auto light
16helpful
8answers
Columbia Watch CL-5030
Hold the light button (top left hand) for a few seconds and the adjustment mode becomes available.
Top Nixon Watches Experts
ZJ Limited
ZJ Limited
john h
Are you a Nixon Watch Expert? Answer questions, earn points and help others
