The glass is still being "PERCIEVED" by the units sensors as dirty.It may have an anomaly unperceived by the human eye. Use Debruce Polish and rest assured you now have a clean surface. DeBruce Polish is "NoN-Abrasive", "NoN-Toxic" AND odorless. Perfect for Stainless Steel and ALL Glass. Find @ DeBruce Polish Non Toxic All Metal Multi Surface Cleaner debrucepolish...
SOURCE: sharp IR 2016 platine glass dirty
The cover plate is above the glass white surface of the scanner. If this is the same dirty stains will come out on copies.
The glass must be clean.
By feeding the original documents through the ADF, the scanner lamp is no longer the path to scan, the ADF is responsible for passing the original document over the scanner, while it remains still placed on the side under a thin glass is to a large glass side. This also must be clean, otherwise you will be black lines on each point or spot on the glass.
Good luck ...
SOURCE: canon ir 2525 is stuck on network download
i have also machine same problem with yours, my friend tell me only canon can solve the problem
SOURCE: How to turn off the message "clean glass" on the
hi Rodney,
first tell me which printer are you using .
