5301 LE 2 Way Car Remote Starter System Logo
A
Anonymous Posted on Feb 24, 2014
5301 fuse location - 5301 LE 2 Way Car Remote Starter System
David Kassin
Level 3:
  • Viper Master 981 Answers
  • Posted on Aug 27, 2022
David Kassin
Viper Master
Level 3:
Answers
981
Questions
0
Helped
199618
Points
2887
1helpful
Pilot light 5301
The Skytech 5301 does not control your pilot light. That is a function of your fireplace's valve. Complete instructions for lighting your pilot can be found in the owner's manual of your fireplace, or at the brand's website.
The 5301 should not need to be reset in any way. Once your pilot is re-lit it will operate normally.
If you need a new copy of the 5301 manual, it can be found at the bottom of the product page here: Skytech 5301 fireplace remote.
2helpful
I have a 5301. Connected last year, worked fine. Installed new batteries, connects and beeps, but fireplace won't light. All controls are in correct position.
I know it seems obvious, but sometimes over the summer people shut off their pilot light, and when relighting forget to move the pilot knob back to the "on" position after the pilot is going - check this first.
Next, you can slide the switch on the Skytech 5301 receiver from "remote" to "on" and verify that it lights the burner. If it does, you may need to re-sync the remote to the receiver. If it does not, check to make sure your wires are nice and tight on the TH & TP/TH connections of the valve.
If you are still having trouble, Skytech has a toll-free hotline for tech support on the 5301. It is: 1-888-672-8929 8am-5pm EST.
My skytech remote is blank I have changed the batteries what else can I try?
The Skytech 5301 Fireplace Remote's touch screen should never be blank, especially if it has fresh batteries (assuming they are installed in the correct orientation).
Skytech offers a generous warranty, you should contact their support team at 1-888-672-8929 to request service on your remote.
1helpful
I had a 5301 installed this week in a 07 Nissan Pathfinder. Everything seems to work fine except that when the vehicle starts the heater & fan does not come on. Did the installer miss a...
Sounds like the tech didnt hook up to the heater acc. wire located at the ignition cylinder. The color of the wire in the car is green\ yellow tracer.... Color of the wire from remotestart is orange. So find where the orange wire from the starter is and hook it up to the green\ yellow wire.
1helpful
I got a 810-5301-c but do not have the operators manual
You should be able to access it from the following website
http://images.brinkmann.net/Docs/Pdf/810-5301-C.pdf
1helpful
Cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Sound fault on advent 5301 after installing
goto google search for your computer driver you can download it from there.
Central locking does not work on 2000 5301
hello, there is a central locking fuse located in the fuse holder above the battery in the trunk. when you access the trim, look on the fuse description on the back side of the trim cover. I believe it may be either fuse #54 or #56. if the fuse is blown, you probably have a failed fuel flap actuator.
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
