My 6003 Elna machine stop and says stop for safety purposes How do I get it unlock from that It wont do anything
This is usually what happens if the bobbin case gets dislodged, its just held in place by a magnet but if you have a jam up, often gets moved out of position. Remove top metal plate, take out bobbin, and have a look at the bobbin case, should be two metal markers or red dotsmfront side that align. Lift the case out by grasping edge and lifting up and towards you, clean underneath with the little brush, remove any jammed up threads, then return case to position, aligning the marks.
