Electrolux EMS2487X Convection Microwave Oven Logo
A
Anonymous Posted on Feb 16, 2014
Power level stuck at stage 1
My microwave power level is on stage 1 and I can't change it. How do I fix this?
Hi I'm Anthoney How do I set the cocking power of my magic chef MCB1110w microwave oven?
Press the Power button several times until the desired power level is reached. Each press of the Power button will reduce the power level by 10%. Using 40% power requires pressing the Power keypad 7 times. After setting the power level, then you can enter the cooking time by pressing the number buttons. Then press Start.
This is shown in the manual which is available at Manuals Lib, https://www.manualslib.com/products/Magic-Chef-Mcb1110w-272833.html . See page 8 to see the positions of the Power keypad; it's to the left of the number keys. Page 9 has a chart with the power level per press of the Power button. See page 12 for the single stage cooking procedure.
I hope this helps.
How do i change the power setting on a Sharp carousel microwave
Which model of Sharp microwave do you have?
For the SMC1441CB, after setting the cook time, press the power level button and then the appropriate digits for the percentage of full power to use. For full power, press power level then 1 and then 0. For 50% power, press power level then press 5.
For the SMC0710BB, after setting the cook time, press the Power button until you see the desired power level displayed on the LCD screen. Press Power once to get 100% power. Press Power 6 times to get 50% power.
For the R-659YW, you set the power before setting the cooking time. You press the Power button several times to get to the desired power level. Pressing Power 7 times will have the microwave cook with 40% of its full power level.
Many current Sharp appliance manuals are available on their product page or the Sharp support page. The current Sharp microwaves are listed here: http://www.sharpusa.com/ForHome/HomeAppliances/Microwaves/Models.aspx?facet:configurationfilter=Countertop . Other appliance manuals are available when you enter the model number in the search bar at http://www.sharpusa.com/Support.aspx .
I hope this helps.
How do I change the power level?
This is from Page 16 in the users manual...
For simple, one-stage cooking, you only need to set the cooking time. The power level is automatically set to High.
If you want to set the power level to any other level, use the Power Level button.
1. Use the number buttons to set a cooking time. You can enter a time from one second to 99 minutes and 99 seconds. To select a time greater than one minute, enter the seconds too. (For example, to set a cooking time of 20 minutes, enter 2, 0, 0, 0.)
2. If you want to set the power level to a level other than High, press the Power Level button, and then use the number buttons to enter the power level.
3. Press the ENTER/START button to begin cooking. If you want to change the power level, press the STOP/ CLEAR button before you press the ENTER/START button, and then enter all the instructions again.
How do I set the power at 50%?
After first setting the cook time---then hit the power level button and hit the number 5 (for 50%) and then start. Power level can also be changed while running by hitting power level button and selecting 1 through 10. For example level 3 is 30% for defrosting.
1helpful
Hamilton beach microwave change power level hp-p100n30al-s3 how do I do that? I pushed the power level button and only beeps does nothing to it
Hit power level button then number 1 through 10. Most have 10 power levels. 1 is extremely low. 3 is usually defrost, 5 would be half power and so on.
1helpful
When I try to change the power level on my Magic Chef microwave, it only lets you put in one digit. How do you make sure its on 100% or 50%?
The oven always starts at 100% power. When you enter a power level from 1 to 9, the control board reads it as 10 to 90% of full power. So power level 5 is 50%, 3 is 30% and so on.
1helpful
The instructions on one-stage cooking don't seem to give an indication of how you handle entering the time, then entering a power level so that it doesn't comfuse tht info with the time setting. How do...
For assistance with your Sunbeam Microwave, please call 1-866-257-3336.
2helpful
How doI change the power on my microwave?
  • Press "Time Cook" or "Micro Cook."
  • Enter cooking time.
  • Press "Power Level".
  • Select a desired power level 1-10 (default is 10).
  • Press "Start"
Detemining the Wattage of a Samsung Microwave Oven
600 watts.
Samsung MU3050W Microwave Oven Consumer Rating: sdc_stars_sm_5.gif See 1 review | Write a review Information: Product details | Product accessories 1-Stage Programmable Cooking. White Cabinet. 15 Min. Timer Optional Mounting. 0.5 Cavity. 600W Output Power IEC-705 Mech. Control Type. MW Distribution - Turntable. 1 Power Level.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Changing Power level on Westinghouse microwave
If it won't cook at the lower power level then it probably has a stuck relay on the control panel circuit board.
If it were cooking at a low power level, it would be on full power for several seconds, then when the relay opens to turn off cooking, the light gets a bit brighter, and the sound is a bit less.
Then after a few seconds you would hear the relay click on, and a little more buzzing when the magnetron energizes.
Please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Electrolux Microwave Ovens Experts
Paul Bade
Jerry Naidoo
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
