Hi, my mirai tv display turns off, randomly but mainly just after turning on. i can hear my virgin home screen if i press buttons and i can some times see it.... for a few seconds. tv worked fine yesterday :s
Check all the solder terminals at its main power regulator board for any loose soldering. Re-solder all the suspected ones, by applying a little more solder, and check. Gopakumar Gopalan Google
SOURCE: When I turned my TV on I can hear the sound but
Most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: RCA L46WD22YX5
Click the link below :----http://wikisolutions.blogspot.in/2012/02/get-free-answers.html
Hey,
Turn off the phone. While the phone is off
