I dont know anything I'm actually doing a report about him and i need that answer before friday or should i saw valentines day i can't wait to get a bunch of candy also wish me good luck because i have to go to funeral tomorrow for my great uncle .so i really need the answer so .HAPPY VALENTINES DAY!!!!!!!!!!!!!!! YAY.
SOURCE: 6102i
Dear check the signal status if there are no signal then may be the antina tips are not touching with the board on antina pad for this reassemble the phone tight the screws. if signal come and go no come agian then its prob from hardware take is to technician.
SOURCE: headlight dimmer switch gone bad have replacement.how do I start?
If you have tilt, tilt the wheel down. Pull the trim plate from around the instrument panel. Remove the screws that hold the switch in.(should be 7mm.)
SOURCE: I bought my son a shift3 usb video camera for
Did you try changing the batteries? if that doesn't work you can return it to the store do you have the sales receipt?
SOURCE: CAFE WORLD on facebook my valentines
You can trigger the Valentine's Day Dinner catering job to show back up on your list of jobs by doing the following:
If you have a CW neighbor who is currently doing the job, bring up their catering job pop-up from your catering truck as if you were going to sign on to help them. Up in the very top left corner of that pop-up is a green question mark. Click on that. Voila!! Another pop-up that explains the Valentine's Day Dinner job and at the bottom has a 'Get Started' button....!!
