I keep getting an E1 error and the dryer shuts off. I took off the lower front of dryer and made sure all the lent is cleaned around inside, but I keep getting the error. I can continue to turn the dryer on and it will dry but I'm afraid I have a more serious problem and I don't want to burn the house down. Any suggestions?
The E1 displayed indicates the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
The thermistor is available from the following: www.searspartsdirect.com
Enter your model # in the appropriate box to get a full parts break-down and diagrams.
To access the thermistor see the image below.
Remember to unplug the dryer from power first.
The thermistor will have a black and red/white wire on it.
You can check continuity across it with the meter and if the circuit is open then the thermistor needs to be replaced.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
The thermistor -may- check ok when cool and freak out when warm!
http://media.fotki.com/1_p,wkrsfrgsskrbttbxgtqsskgwtqkq,vi/wbsdwtgwgxwrgbbgsgs/1/1303472/5961857/image6767img-or.gif
HE3 Dryer: http://media.fotki.com/1_p,wbfbgrrwtrrkfttxgtqsskgwtqkq,vi/kgwgwwwdkxkfkkgwgqs/1/1303472/5961857/image7127img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
