I have a Canon Powershot Camera, a few years old, I've never had a problem with it. I only have a 512MB card in it, but I bought a 4GB and it says "memory card error" or "card locked" The card is not locked, and when I try to use the format option on the camera, it is not a valid option. I have tried 2 different cards with no luck. My old 512 still works, but I want to be able to take more video. Do you have any idea why my camera will not use the new 4 GB cards?????
It's a good bet that anything 4GB or greater is a SDHC card (look on the card, see if SDHC is written there). Your A530 was designed before the new SDHC format came out. Sorry, but your camera will not recognize this type of card. Recommend instead that you get a 2GB standard SD card. They're relatively inexpensive these days.
SOURCE: Want to use 4GB sd card in Polaroid i832 but all
A 4GB card is known as an SDHC card...probably not accepted by your camera. Stick with the manufacturer's recommendations. You could go to the support section of Polaroid's website to see if they have a download for your camera model that would permit the larger card.
SOURCE: When in insert my SD Compactflash cards 128MB,
Same problem but with a different camera. Turns out, these cameras are very... may I emphasize very... picky as to which cards to use. Try other off-brands and you'll be surprised as to what it takes.
The following digital camera memory cards are
compatible with your BenQ DC E53. Every digital camera memory card we
offer is manufactured to the highest standard and carries a 2 year
minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
