Pool & Spa Logo
A
Anonymous Posted on Feb 07, 2014
20 year old Teledyne Laars pool heater started making a "buzzing" sound when nothing is running
Mike Tellegen
Level 3:
  • Pentair Master 1,631 Answers
  • Posted on Apr 05, 2015
Mike Tellegen
Pentair Master
Level 3:
Answers
1631
Questions
Helped
1013257
Points
5840
Make and model?
if IID, then it's possibly the IID box, or Gray Box.
its the only component with an electric coil to a relay!
they commonly buzz.
5 Related Answers
lyngaaskhan
  • 4 Answers
  • Posted on May 23, 2009
SOURCE: Hello
http://www.parts4heating.com/Pool-Heaters-Teledyne-Laars-parts-s/38.htm
Anonymous
  • 139 Answers
  • Posted on Jun 21, 2009
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Anonymous
  • 139 Answers
SOURCE: My teledyne laars pool heater will not cycle on. The pilot is lit and the valave is in the on position
check millivolt output should be 400-600.if less than that you dont have enough voltage to power valve
Anonymous
  • 9 Answers
  • Posted on Jun 28, 2009
SOURCE: Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
Anonymous
  • 3 Answers
  • Posted on May 29, 2010
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
1helpful
Heater comes on but getting cold water in pool return, heater is 7 years old never had problem before!
if you have a two speed pump,try it at slower speed to keep water in heat exchanger longer
Starting a teledyne laars heater
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
