20 Most Recent Pentair Minimax NT Heater Questions & Answers
Pentair MiniMax NT, won't stay lit.
Check the hose going from the fan housing to the control board. I found that it was very loose at the fan connection; wrapped a thin strip of masking tape around the barb, reconnected the hose and it works fine now.
11/12/2022 4:52:41 PM • Pentair Minimax... • Answered on Nov 12, 2022
Code e02 lay-z-spa monaco please help
11/8/2022 9:53:40 PM • Pentair Minimax... • Answered on Nov 08, 2022
2answers
Purex Triton MiniMax Plus 400
if you have incoming power, you may have a bad transformer. those systems run on 24-28v. you can check from yellow wire to yellow wire coming off the transformer to see if you have anything coming out. must check wires coming out of the transformer to each other, it won't register if you check each one individually to ground. hope this helps...
5/25/2021 9:39:21 PM • Pentair Minimax... • Answered on May 25, 2021
2answers
Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
12/29/2020 8:54:58 PM • Pentair Minimax... • Answered on Dec 29, 2020
2answers
R=5 CODE ON A PENTAIR HEATER ?
flame sensor falure, probally your pilot.
6/26/2019 8:14:11 AM • Pentair Minimax... • Answered on Jun 26, 2019
2answers
Heater has been running and heating, but getting E02 error and HI
sounds like a water flow issue check your bypass valves check for clogged filter or thermal regulator ,or manifold bypass
6/26/2018 3:13:20 AM • Pentair Minimax... • Answered on Jun 26, 2018
0answers
Minimax NT.. Shows green power
I would call the Pentair technical support line because they may be able to help you figure this thing out. I hope this helps.
Please vote on this answer. Thank You.
12/10/2017 6:45:22 AM • Pentair Minimax... • Answered on Dec 10, 2017
0answers
0answers
Pentair Minimax NT Heater Logo
421 questions posted
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Pentair Pool & Spa
  • Pentair Pool & Spa
Most Popular Question
like turn caller id ntl d5100 let me
  • Pool & Spa
