You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
The codes are good for several models.
I have followed your advice and after clearing the C7 error the scanner moves in one way then return, but the red wrench light of the copier is still blinking and the C7 code is still there. Even preheating slightly the thermistor the red light continues to blink.
In fact, soon after the copier is powered on, the red wrench light blinks.
Finally, I did reset the C7 code. Everything you said for the C7 code reset was ok but in place of 87 you put the 89 number and it worked fine.
Thank you very much for your help
