WHAT WAS THE CAPACITY OF THE MAIN FAN OVEN
SOURCE: I'm looking for an instruction
Let me have an email address for you and I will give it access on my BT Digital Vault for you to down load a copy that I have scanned.
SOURCE: STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
SOURCE: reconnecting terminals onto stoves 900GTF double gas oven
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
SOURCE: i have a stoves Q 720 EM Do oven and l have lost
The fan is squeaking/rattling in our Stoves q720em double oven. Any easy / cheap solution please!?
SOURCE: Hello, i have a stoves
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
