20 Most Recent
Stoves Premier 720EMa Electric Double Oven Questions & Answers
How do I replace a blown buld in the main oven
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Cooling fan not working on
Probably went bad a lot of exhaust dirt gets in there. Make sure power is off take it out and replace it ,you can find one at your local Grainger if not they can match it up.
Hi Top oven only gets warm no matter where you set
I have a 720ef and the top oven is not that good. The wattage rating is low, from memory about 750 watts and it takes a month of Sundays to warm up. I bought an oven thermometer from Lakeland a little while ago and when the top oven is turned on the Lakeland thermometer is showing that the oven thermomostat is running the oven at 20 degrees below what it is set to. If the thermostat neon is clicking off and on, then the thermostat/oven is working, albeit not as we expect.
Dual grill does not work
It sounds like you have no power to the the grill. Check the grill circuit with a tester until you identify where you have power to and then check for loose connections or broken wires from there on.
Stoves 900GTFThermal Switch
If you have paid for warranty insurance, read the small print. I think you will find, if it is not repairable, they must replace it with an equal or better unit.
10/16/2022 2:54:47 PM •
Stoves Ovens
Answered
on Oct 16, 2022
