Hello, the only other way is toget a password cracker.Go here for password help.
Ophcrack
SOURCE: administrator password
If you don't have to enter a password to access the BIOS, you can go in and remove the requirement to enter a password on Bootup.
Otherwise you can unplug the computer from power, unplug the power supply, and then remove the battery on the Motherboard to clear any stored BIOS and Bootup passwords.
SOURCE: lost password to 170L administrator
Try password =password
or administrator or admin or Admin, Administrator, or ntadmin, NTadmin
and let me know
SOURCE: Factory Reset
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received
SOURCE: Forgotten Administrator Password
An easy method to recover or reset windows administrator password is using Anmosoft Windows Password Reset, it's a powerful Windows password recovery tool.
SOURCE: i need to change the
If you often change your Windows password or your memory isn't good, it is normal that you forget the password. To help you remember, or on the lowest to help you be in control and know your password, why do not you obtain a software program plan that will reset the password for you? The software program plan is capable of resetting and positively removing the more mature password in purchase for you personally for getting in a location to available your operator account. Why do not you consider a glance at this software program program? Please visit: http://www.passwordseeker.com/howtouse.html
