DMX i-4308 reverses the feed before each label printed. The problem is that the reverse feed is reversing so far that the print head is losing pressure on the label and the prints are coming out badly aligned or not feeding at all. Where is the setting found to adjust the reverse feed distance?
SOURCE: Paper feed to far for labels
Adjust the paper size manually.. And Scale to a particular size.. Re-installing the driver may fix the problem... To download the driver please click on the below link or copy the URL and paste it in your web browser. Select the operating system you are using and download the driver.. Hopefully it should work....
http://www.epson.co.in/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=11&pid=115
To download the manual, click on the below link..
http://www.epson.co.in/epson/manuals/manual_download.htm?dc=1&mode=3&m=false&catid=11&pid=115
Thank you.......
SOURCE: Z4MPlus Ribbon wrinkles causing lines diagonally across label.
Could be down to tension on the ribbon roller/spool. Check to see if you have pulled out the end part of the spool (black bit) that should ensure there is back tension on the ribbon.
SOURCE: the printer will print one
This sounds like a size issue, meaning that your label has too many lines and that kicks to the "next page".
Look for too many line items on first label.
