The inside of the glass on the front door is stained - how can I remove it for cleaning?
Use DeBruce Polish on GLASS. Make sure the stains are NOT inside the "sandwich"
DeBruce Polish Non Toxic All Metal Multi Surface Cleaner debrucepolish...
SOURCE: Permanent (?) stains on inside of door
Have you tried a treatment (not sure of the name) that you wash plastic dishes with that takes the orange stains out? It can be found at Walmart for under $10. I don't know of anything that can prevent this problem but I don't see why a product that takes it out of plastic dishes can't take it off the plastic of the dishwasher. Hope it helps!
Below are instructions on how to take your oven door apart to
remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit
driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. With door in broil stop position lift door assembly off
hinges.
C. Lay door on table, position so that handle hangs freely over
edge of table
D. Remove 2 screws and washers that secure handle to lining
assembly.
E. Remove 8 screws that attach textured steel door wrapper trim
to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of
lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps
attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass
just lays onto the wool shield and is held in place by the glass/ clamps in
item
H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this
time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
