Want to add 2nd monitor but only have USB available on computer
SOURCE: imy 15-pin vga port connecting to the monitor has 3
I am sorry but there is no way to replace just the three broken pins. You can replace the entire vga plug but it requires stripping down each individual wire and soildering a new one on. You can pick up a 15 inche monitor for next to nothing. Try ebay.com you can get a nice flatscreen for a good price. I am sorry.I wish you all the luck in the world.
SOURCE: Viewsonic VG2021m monitor no longer showing a picture
Hi!
there are possible reasons why your monitor shows nothing on your screen...
First, you need to check if the power cable of your monitor is well connected to a wall socket or AVR (and that you are sure there is supply output current on the AVR or in the wall outlet)
IF found that power cable is fix and secure... my suggestion is you bring the monitor to a credible technician...Because the possible reason why only black is seen on your screen, is because the backlight inverter could be busted already.. the backlight inverter which is located on the upper and lower back edge of the monitor is the light source responsible for giving image display of your lcd monitor.. Another reason could be is a deffective high voltage ballast transformer which is responsible for generating high votlage supply for the backlight....
It is too risky for you to do the repair by yourself without proper knowledge and right tools to do this.. So don't waste time consult a technician and or possible avail of the warranty if there is any...
Hope it is clear now to you..
Much appreciated if you rate this help.. thanks..
SOURCE: LCD monitor (viewsonic va720) "No signal"
Some Laptops or PCs will only work with a 2nd Screen or monitor option on LCD, :Projectors or TV screens.
On Display/.settings/ on PC you can select 2nd monitor option and apply.
U should see your LCD screen flicker and displays your PC 2nd screen
