General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459 Logo
A
Anonymous Posted on Jan 19, 2014
Cannot set time for GE JCB840SFSS - General Electric Stove/Oven/Range Chrome Timer Knob Set - WB3X459
Timer GE15119 should the lamp be on when you plug the timer into the wall outlet ?
It is a very basic mechanical timer. I have 3 of them.
Remove it from the wall.
Pull the tabs up for Off and Push tabs down for On.
Set the Time by turning the dial, time to arrow.
Set the slide switch to Timer On.
Plug in the appliance.
Plug the timer into the wall socket.
Manual and Advertising is here.
GE 15119 Manual - Waterheatertimer.org
http://waterheatertimer.org > pdf > GE15119-Man...
PDF GE 15119 timer manual http://waterheatertimer.org/How-to-set-timers.html http://waterheatertimer.org/GE-timers-and-manuals.html#52012.
GE 15119 Indoor 24-Hour One-Outlet Plug-in Basic Timer ...
https://www.toolboxsupply.com > products > ge-15119...
GE Indoor 24-Hour Mechanical Timer is an easy-to-use basic timer. Ideal for lamps, seasonal lights and portable fans. Turns a lamp on/off at desired times daily, ...
How to set clock
See here (
GE JNM7196SFSS Use And Care Manual About The Other Features Cooking... ) Paraphrasing from the site:
  1. Press the [Settings] button 2 times.
  2. Enter the Appropriate time of day
  3. press [Settings] to indicate AM or PM
  4. Press [Settings] to accept the time.
You can find both the owners and the install manual here (
GE Microwave Oven manuals ) Scroll about 2/3 down the page, looking for just JVM7195.
Good Luck!
Need information on how to set time & date on a GE
Press and hold the STOP/SET button for two seconds, then release to access the set-up menu. The time/date setting follows the language.
The full details are in the "Changing the Settings" section of the manual (page 10 in my copy). If you need a copy of the manual, you can download one at
http://www.home-electronics.net/ge/pc/IB/29875GE1_IB.pdf
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
To override time and turn on Load, move override to ON position.
1helpful
How do you set the time on a GE 29196GE1-A wall phone
I found the user manual on line and learned that the phone had to be connected and receive a call to automatically set the time. The user manual can be found at: http://www.thomson-asia.com.hk/Thomson_Asia/GE/file.aspx?filename=GE/product_docs/29196%20User%20Guide.pdf
7helpful
How to set time on my ge phone 27958GE1-A
just before you press the button to set time, press "0"
How long do I set my ge oven to clean or is there a time set??
Normally the cleaning cycle is preprogramed by the factory, some models have a time setting which you can set, but for most, its preprogramed, there is no adjustment to the time, it will lock, run, and unlock to its programing, hope that helped.
2helpful
5answers
GE Dect 6.0 digital cordless phone about 1 year- old how to set time
I have a GE 6.0 cordless & it did work great but, Now for what ever reason it crackels & the static is so bad i can not understand those who call me . I love this phone so please help me. ?
Top General Electric Hardware & Accessories Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
