20 Most Recent GE DVLR223 Dryers Questions & Answers
2answers
The dryer stopped working in the middle of drying
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
5/7/2022 5:09:47 PM • GE DVLR223... • Answered on May 07, 2022
I have a dvl223Eb6ww dryer..heats great but started making a scratching noise that seams to get louder as the dryer gets hot..what could this be..we took it apart and the belt seams fine heating eleme
Sounds like you have bearings problems that need need grease. Normally the drum rests on two separate bearings up front and one located at the drum center at the rear. Since you know how to take it apart you should be able to locate the bearings. A mall amount of general purpose grease will do the trick. The scatching noise may come from loose object floating around, may be a shirt button ? investigate. Good luck and good repairs. A dryer repair is not too difficult since you have already checked to condition of the belt...Here an extra tip for the performance of your dryer, always clean the screen air filter with soap an water to remove the invisible screen deposit by the Fabric Freshner Sheet also called Fleecy. This will allow air flow to exhaus the dryer more freely.
8/21/2017 8:25:28 PM • GE DVLR223... • Answered on Aug 21, 2017
Which is hotter on my
Regular heat is hotter and sould be a shorter run time.
8/6/2017 2:32:27 PM • GE DVLR223... • Answered on Aug 06, 2017
Dryer makes a squeaking/high pitch rubbing noise
bad drum bearing, bad drum teflon pads or both possibly or both possibly or in combination the belt could need replacing & if your not sure get a service tech so you dont do more damage
2/9/2015 2:26:13 AM • GE DVLR223... • Answered on Feb 09, 2015
Does the ge model dblr333e have a fuse inside and high heat stopped working
sounds more like a thermostat
2/9/2015 1:51:17 AM • GE DVLR223... • Answered on Feb 09, 2015
Dvlr223ee0ww GE dryer will not turn it gets hot but will not turn
Check the belt.
5/17/2014 6:30:26 PM • GE DVLR223... • Answered on May 17, 2014
0answers
0answers
Well i wanna know the wires of the timer touch a metal cover and did a short cut my question is do i need to change the timer of what else do you think could be the problem a fuse ?
you'll have to call in a tech to check it out or replace the dryer,nobody can answer that question without being there and checking the dryer with a meter,if the wires from the timer touched metal and i can't see how that happened unless someone worked on it without unplugging it you could have cooked just about any wire or part that those wires go to but then again you could change the timer and it could work but you have to check it with a meter first,that timer cost around 140 dollars,to much money to just guess at.
11/23/2013 10:40:51 PM • GE DVLR223... • Answered on Nov 23, 2013
Gas dryer no heat
the model you sent is for a g.e. electric dryer
11/23/2013 10:31:58 PM • GE DVLR223... • Answered on Nov 23, 2013
3answers
No heat
Most likely you have a burnt element....A good handy man could replace the element fairly easily.. Cost of a new element about $50-$75
11/8/2013 1:47:47 AM • GE DVLR223... • Answered on Nov 08, 2013
My Hotpoint TVM570P is making a dreadful noise.
Get a piece of hose and listen to each bearing. The hose should help isolate the problem.
10/23/2013 7:19:59 AM • GE DVLR223... • Answered on Oct 23, 2013
Ge electric dryer will not start model number dde
Thermal Fuse
9/25/2013 4:54:28 PM • GE DVLR223... • Answered on Sep 25, 2013
Dryer dries clothes but does not stop running - dial doesn't move
What is the make and model?
7/11/2013 5:27:54 PM • GE DVLR223... • Answered on Jul 11, 2013
GE model: DVLR223GG8WW won't start
Check the door switch for continuity. Here is the switch to order in case it is bad.
12/3/2012 12:43:50 AM • GE DVLR223... • Answered on Dec 03, 2012
DRYER WON'T START WHEN START BUTTON IS PRESSED.
The fuse is located on the heater element which is bolted to the back wall behind the drum. 12_2_2012_8_13_17_pm.jpgI have several home movies and repair pix on my DIY blogpage:PAW PAWs DIY GE HOTPOINT DRYER Repair page If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
12/2/2012 8:15:02 PM • GE DVLR223... • Answered on Dec 02, 2012
Dryer stops and starts, on and off on and off,etc.
Does the heat start and stop or does the drum?
11/4/2012 4:19:34 PM • GE DVLR223... • Answered on Nov 04, 2012
GE DVLR223 Dryers Logo
141 questions posted
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
View Most Popular
GE Dryers
  • GE Dryers
Most Popular Question
hotpoint tvm570p making dreadful noise
  • Dryers
