LeapFrog Tag Reading System Logo
Narelle Clarke Posted on Jan 19, 2014
Leap frog scribble and write. Pen wont work. - LeapFrog Tag Reading System
Stefanie Guerrero
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 24, 2014
Stefanie Guerrero
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
21842
Points
It only works for the specific leap reader pen paper
3 Related Answers
Anonymous
  • Posted on Sep 17, 2012
SOURCE: leap frog tag pen won't work any longer.
I found that after replacing the batteries, the power button on the reader did not work. I did however have luck after I connected the Reader/Pen to the laptop, updated the s/w on the reader and updated the s/w on the laptop. Then the reader was able to interact with one of the books just fine.
Anonymous
  • Posted on Jan 29, 2011
SOURCE: Replacement Leap Pad Pen
Hi, I have found this pen on www.leappadpen.com
I hope that this helps?
Regards
Anonymous
  • 10865 Answers
  • Posted on Jun 08, 2009
SOURCE: My daughter's Leap Frog Tag reader pen will simply
Hello I will try to help you. If the pen was working up until the batteries died then the problem logically would be solved by putting in new batteries. That said, remove the "new" batteries and install them in another device to be sure that they are good. Some new batteries die in the package before being used.
Then make sure you are putting the batteries in correctly, pay attention to the + and -.
Finally, you can clean the ends of the battery chamber by using a pencil eraser and rubbing it on the metal contacts.
Let me know if one of these things fixes your problem as I have additional ideas.
Leap frog leappad 2
Recommend contacting Leap Frog directly for technical support by clicking here:
Contact Us
2helpful
Leap Frog Scribble and Write won't write
I fixed one by taking it apart and cleaning the 2 pieces of plastic that cling together with glass cleaner. It actually works better then when we first opened the gift. It is a tedious job but now that I've done it once I can probably fix it again in about 20 min. The hardest part is reattaching the spring mechanism which pulls the screen taught. The parts are kind of small.
1helpful
The pen hs stopped wotking on our leap frog globe
If you are in the US, you can call their Consumer Services number at:
1-800-701-5327
They will be able to help you get a new one.
Thanks for using Fixya.
Leap frog globe pen no longer works
Either the wire is broken inside the insulation, or the batteries are dead.
5helpful
Leap frog globe pen replacement
The leapfrog webpage gives this info for getting replacement pens:
"If the pen was physically damaged (your dog chewed it, your child ripped the cord, etc.) the replacement cost is $5 to cover shipping and handling. There is no need to send the damaged pen back in this case. Simply call our Consumer Services center at 1-800-701-5327 to order a new pen."
http://leapfrog.custhelp.com/cgi-bin/leapfrog.cfg/php/enduser/std_adp.php?p_faqid=23&p_created=996471052&p_sid=mNlXPJDj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAsMTAmcF9wcm9kcz0wJnBfY2F0cz0mcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1nbG9iZQ**&p_li=&p_topview=1
2helpful
I need to order a replacement pen for my leap frog globe
Call their Consumer Services number at:
1-800-701-5327
2helpful
2answers
I need to order a new pen for Leap Frog's Junior Explorer Globe
Call their Consumer Services at 1-800-701-5327. They will be able to help you order a new one.
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
