GE JTP86 Electric Double Oven Logo
Posted on May 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
The see through glass on my oven door is cracked.  Does the entire door have to be replaced or will I be able to replace just the glass see through window? I have a GE built in self cleaning wall oven and the glass on the inside of the door is broken.Can the glass be replaced and where?
Anonymous
Level 3:
  • Master 1,136 Answers
  • Posted on May 30, 2009
Anonymous
Master
Level 3:
Answers
1136
Questions
0
Helped
354519
Points
4025
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
1 Related Answer
Anonymous
  • 2920 Answers
  • Posted on Jan 12, 2009
SOURCE: Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
you should be able to just replace the glass
Frigidaire double wall oven clean between the glass
Remove door off the hinges. Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Whirlpool wall oven glass door cracked+self cleaning feature does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
The inner oven glass of my self-clean oven has a small crack. Can I still use the self-clean feature?
No, that may be what cracked it in the first place...the self clean or self destruct feature will noly finish it off for you...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
2helpful
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Is it possible to clean between the two pieces of glass on the oven doors?
You would need to take the door apart, and even then the glass isn't really made to be taken apart. So it COULD be done, but it would be easier to buy new glass and replace it. It all depends on how much you want it to look clean.
2answers
Cleaning between oven glass
You must unscrewed inner door,there is screws around edge door inside,try it.
Jan 12, 2009 • Ovens
I don't know where to look for a Glass Cooktop Replacement
What is your model number and I can look up the part and tell you what they cost so you can call some appliance stores for comparison
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
