20 Most Recent Frigidaire 27 in. Electric Gallery Pro Series Self-Cleaning Double Wall Oven Questions & Answers
35 years old? Ya gotta be kidding.
Frigidaire 27... | Answered on Jan 27, 2018
Break the problem up. Start at the elements. Do they get power? If not work your way back to the output of the control. Is there power there? If not replace the control. Otherwise check all wiring
Frigidaire 27... | Answered on Jan 14, 2015
Thank you for your post, Genie Byrd!
From my understanding your Frigidaire refrigerator is not sealing properly which is causing an issue with your icemaker. You may need to replace the component for your seal. I would recommend having a professional technician out to your home to properly diagnosis and repair your refrigerator. Are you under warranty? Typically, if you are under warranty a repair should not come out of your pocket. I would consult with your manufacturer for warranty coverage. Hope this information helps. -OOS
Frigidaire 27... | Answered on Nov 29, 2014
Remove door off the hinges. Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
Frigidaire 27... | Answered on May 19, 2014
Sears has it. Go to searspartsdirect.com or it you live near Roanoke, va you can go to Tribles on Shenandoah NW near southern refrigeration and the Hill top restaurant.
Frigidaire 27... | Answered on Feb 14, 2014
Hello Bree, thank you for allowing me to assist you!
Let's try resetting your wall oven by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your appliance on. Now set the time and try turning on the oven. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, a communication error with the EOC (electronic oven control), faulty door latch assembly or element(s). Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Frigidaire 27... | Answered on Dec 16, 2013
Your high limit thermostat is either tripped or blown. must remove unit from wall it is on the back wall of oven under panel. I would suggest having a professional look at it for you.
Frigidaire 27... | Answered on Jun 03, 2011
May be the sensor or the control. Try sensor first. Way cheaper
Frigidaire 27... | Answered on Nov 04, 2010
Chances are the ignitor is weak and needs to be replaced. When they get weak the resistance is not proper to open the gas valve.
Frigidaire 27... | Answered on Sep 17, 2010
check the timer to see if its still on
Frigidaire 27... | Answered on Dec 12, 2009
3 hours or so....and it will stink
Frigidaire 27... | Answered on Sep 20, 2009
F8 Oven door lock failure Check lock relay and door switches.
Frigidaire 27... | Answered on Apr 02, 2009
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Never ever use the Clean Mode. It breaks things, in your case over heating the fan. The clean cycle goes up to 650'F
Frigidaire Ovens | Answered on Nov 14, 2019
First take out the broiler pan, insert and any aluminum foil. Remove any other tools or pans from the oven. Next clean any large deposits in the oven cavity with hot, soapy water and a cloth. Clean the oven frame, the area outside of the door gasket and the very front center of the oven bottom with soap and water. Once you are ready to start the Self-Clean cycle, press the Self-Clean touch pad. To change the length of the Self-Clean cycle, press the pad again, as needed. Press Start. If you want to have the Self-Clean delayed, press the Delay Start touch pad after the Door Loc message appears. Type in the start time with the keypad.
To stop this cycle, press Cancel. If the oven is hot, the door will remain locked.
Frigidaire has most of their manuals available on their support site: http://b2b.frigidaire.com/support/manuals.asp . The current link to the English version of the Owner's manual is http://manuals.frigidaire.com/PDFnotFoundCheck.asp?path=ftp://ftp.electrolux-na.com/ProdInfo_PDF/&folder=Lassomption&PDFtype=Owner&PDFfile=318205312en.pdf&model=FGEW3045KFB . See pages 24-25 for this information.
I hope this helps.
Frigidaire Ovens | Answered on Nov 05, 2019
Possibly, the replacement EOC is defective.
Frigidaire Ovens | Answered on Oct 06, 2019
Frigidaire 27 in. Electric Gallery Pro Series Self-Cleaning Double Wall Oven Logo
20 questions posted
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Alan Chouinard
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
frigidaire gallery refrigerator bottom
  • Ovens
