I just received my machine yesterday (ordered from Amazon). The presser foot was loose in the box when I opened it. I reattached, but the whole needle mechanism is out of alignement with the hole in the presser foot and the opening to the bobbin (hits on the left). It seems to be on an arm that can be moved, but I can't figure out how to make the adjustment.
SOURCE: Needle doesn't line up
With the pattern dial set on the straight stitch, you can align the needle by turning the width dial and setting it to about 2.5 ( so that the needle will stay in the center).
SOURCE: I have a problem with the needle shaft. It seems
Remove the foot - does the needle hit the needle plate?
Is the needle bent?
If the answer is no to both questions, it could be the machine needs to be taken in for repairs.
SOURCE: needle will not move; the bobbin shaft is in the
Force the balance wheel backwards, you may have thread stuck round the raceway
SOURCE: Bobbin won't wind. Machine
Hi, take the top of the machine cover off by removing screws on top plastic cover. Make sure that the rubber ring on the wheel that turns the bobbin threader is making contact with the belt from the flywheel in the back. You may need to see if it turns freely. If not take it off and lubricate it until it frees up and then replace it and the cover.
