Yes
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: Intermatic T103 - It was working. However, now I
Intermatic has had an issue with the main drive gear striping in there timers, I don't know of any best practice repair method for this part, I suggest you replace it or if your not electrically comfortable call a local electrician.
Hope this helps...
Tim
SOURCE: My intermatic timer won't trip back on
I don't think the timer runs on 240 volts does it? You can switch 240, but the timer uses 120 volts to run. You might check the connections and timer clock rating more closely. Also, the 'off' & 'on' trippers are different, make sure you use the right one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Intermatic T104R clock not working.
here is a link to the wiring diagram, u may not have the clock motor hooked to the right terminals. http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t104%20-%20english.ashx
SOURCE: Intermatic T103 timer wired for 240V
yes u will, but u will have to make sure one of the motor wires are hooked up that way also, in case it has been moved, here is a link with the diagram u need
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t103%20-%20english.ashx
SOURCE: Circuit breaker keeps tripping when timer turns
Since the timer doesn't trip the breaker until it turns on the load, the circuit is OK up to and including the timer. Either the load is faulty (has a short) or the wire supplying the load is damaged. You can test the wire that supplies the load by disconnecting the load then turning the manual switch to ON. If the breaker doesn't trip, then you know it is the load itself that is causing the problem.
