20 Most Recent Intermatic & Indoor/Outdoor Rain Tight Timer Questions & Answers
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
Intermatic &... | Answered on Mar 14, 2019
search on google
R8806-Instructions-EN.pdf.pdf
This is a 240 VAC timer
There is No Neutral
Intermatic &... | Answered on Jan 11, 2018
Clock motor bad? Wiring reversed?
Wiring and troubleshoot and parts list following link:
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Intermatic &... | Answered on Oct 30, 2017
It would be highly unusual for a sprinkler timer to be 220v.
They require very little power, unless they're industrial to control a golf course or something.
Intermatic &... | Answered on Oct 24, 2017
Make sure that the tab for "ON" is secured tightly to the time wheel. If it is loose, it may twist out of the way and delay the start. Hand tighten it and give it an additional 1/8th of a turn with a pair of pliers to snug it down more than hand tight. Do not over tighten.
Good Luck!
Intermatic &... | Answered on Oct 04, 2017
Tip
Intermatic Timers
This is Intermatics reference page for all the timers hope this is helpful https://www.reference.com/?o=36355&qo=contentPageReferenceLogo Reference com What Your Question
on Mar 03, 2017 | Intermatic & Indoor/Outdoor Rain...
replace it, I would get the same brand cuz they are so reliable and simple to use. if you need help hooking it up just give me a holler. not sure how u do it tho so hippy_dd@hotmail.com
Intermatic &... | Answered on Jun 13, 2016
If dial is not rotating clockwise and keeping correct time on 240Volt T104 timer, then WG1573 clock motor is probably bad.
Open following link for troubleshoot checklist:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Intermatic &... | Answered on Aug 23, 2015
reverse the wires to the timer and it will run clockwise.
Intermatic &... | Answered on Aug 22, 2015
t8845pv has 120Volt input, and 24Volt output.
See wiring diagram for T8845PV controlling 120Volt pump using contactor
Intermatic &... | Answered on Mar 04, 2015
Open link to for wiring typical T100 series, and T170 series timer
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
More timers shown following links:
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/How-to-wire-WH40.html
Open following link to help identify and use typical timer.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
if its an intermatic timer like the pic looks like got the link and see if u have any luck finding it. you can get the wiring specs there. I have searched it with the info posted and no luck, so u need to find some other numbers on it I think Search
Intermatic &... | Answered on Mar 03, 2015
you should b able to find a model number inside if not outside, with that I can give u real help instead guess what I think it is.
thank you
Search u should be able to find what u need here
Intermatic &... | Answered on Mar 01, 2015
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
429 questions posted
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Mike
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Intermatic Hardware & Accessories
Most Popular Question
model t101 keeps switching from manual
  • Hardware & Accessories
