MY FRONT LOADER NO LONGER BEEPS WHEN WASH IS DONE OR AT ALL. CUSTOMER SUPPORT HAD ME TURN IT ON TO A CYCLE & PRESS BLEACH & RINSE SEPARATELY BUT NO SOUND. THEN PRESS THEM SIMULTANEOUSLY STILL NO SOUND. EVEN THOUGH IT DRIVES MY CRAZY I STILL WOULD LIKE TO KNOW WHEN THE LOAD IS UNBALANCED OR THE WASH IS DONE.
SOURCE: detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
SOURCE: front loading washer does not advance past the rince cycle
Check and clean filter, it is usually located behind a plastic panel at the bottom front of the washer, remove cover and unscrew the filter cover anti clockwise, pull out and clean, replace and test, if it still does not drain, then possibly pump blocked or faulty.
Plz rate my solution.
Thanks.
SOURCE: Bosch WFL 1660 Front end
After disconnecting the mains open up behind, it could be a shock absorber (damper) which is broken.
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
This error code indicates that an unbalanced load is detected.
Click the following to learn more about unbalanced loads in the BravosTM washers. The example is for an impeller washer but is applicable to washers with agitators.
Is the wash load balanced? If the load is unbalanced, the washer will display this code while attempting to balance the load at the end of the wash cycle and before the final spin. If the code remains and the wash cycle dial is flashing after the recovery routine has stopped, open lid and redistribute the load. Close lid and press Start/Pause. Is the washer level? Does the washer rock when pushed against the corners? If the washer is not level, the washer may be more sensitive to unbalanced loads. The washer must be level from side to side and from front to back. The front and rear feet must be in firm contact with the floor. Make sure the locknuts are tightened. See the Installation Instructions for details. To remove the error display, press Power/Cancel or Pause/Cancel once.
