Help, I haven't used my DS-150 for a couple of years. The software is version 3.1 not compatible with my computer, can I update? The recorder works fine but I cannot upload to computer software. Thanks!
SOURCE: DS-2 Olympus Digital voice recorder
You can buy the disk but there is a download.
DSS Player (version 7.0): is
available via download as a courtesy, please follow the instructions
below: http://www.olympusamerica.com/files/DSSPlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 7.1: http://olympusamerica.com/files/DSSV7UP2EN.zip
Serial #:(8360-0101-0027-7420-4735 )
SOURCE: can't get the software to detect the device
should be no compatibility problem.. not with xp... but you can check two different things... first check the "safely remove hardware" icon usually beside the time in the system tray. when you click on it once, it should say safely remove usb mass storage device drive *: (star representing drive letter), if no letter comes up then no drive letter is assigned and will have to go thru drive letter assignment.
the next thing would be in device manager in system properties... it should be recognized as usb mass storage device and disappear if you unplug your device. if not then the driver may need updating through microsoft
i would call Oly tech support so they can walk you thru the getting your device to work properly
SOURCE: converting wma files to wav files on olympus DDS player version 7
When using the DSS Player v7 software the program is unable to convert WMA to WAV. The option you see there only works when it is a .dss file that needs to be converted to .wav. In order to convert WMA to WAV you will need to locate a third party software program that does this type of conversion.
Go to google and search on WMA to WAV conversion editors.
Same problem but my software CD was stolen along with my laptop. I haven't used my DVR for a couple of years but my son who is first year university would like to start using it. Where can I download the software and an English version of the manual? Thanks
Yes, I want to use mine too but software won't load onto XP? There should be a solution somewhere for this....
Same Problem - but I alos need drivers for the Olympus DS-150
Have lost Software CD for Ds 150. How do I get it for Windows XP?
i have the same problem, i see upgrades on the olympus site, but i dont know where to start. darn it! i could get my win 98 laptop out i guess. i never had it installed in the first place!
