Phone displays searching for base
SOURCE: "searching" message even when handset on the base
Found the following in AT&Ts FAQs for your phone, I'll leave only what might be relevant: # Charge the handset for 12 hours. After the first charge, the battery will quick charge in only 8 hours. Re-cradle the handset nightly for recharging. The battery will not overcharge. # Connect telephone line from base to unit to modular telephone jack. If cord is already plugged in, unplug and reconnect at both ends. Also, you may want to try another cord from a working telephone. See the owner's manual under "Connecting to Phone Line." (you can get the manual here on the product page in case you lost it) # Try a working phone at the jack. If another phone has the same problem in that jack, the phone jack is defective. Good luck, hope you work it out
SOURCE: Phone Installation - Out Of Service
Find the manual on the link below. Check batteries are charged preferably for a few hours then perform the reset as per the manual: To re-initialize the handset and base: 1 Disconnect the power to the base. 2 Remove the handset battery pack. 3 Wait at least 15 seconds. 4 Insert the handset battery pack. 5 Connect the power to the base. 6 Put the handset in the base to re-initialize. 7 Wait for handset to display READY (or handset name). http://telephones.att.com/docMgt/public/art/306/2255_.pdf
SOURCE: My 2 year old base has power but no dial tone. It
This might sound silly, but have you tried plugging another phone into the wall jack to make sure it works?
SOURCE: Cordless phones display searching for base.
Same problem: registering base ID on cordless get T23 PD error and subsequently, Searching for Base
