Try www.ovenlettering.co.uk. Mark the owner will find accurate decals of your cooker confirm it with you and send you two sets plus degreaser. Follow the simple steps from the sites video instructions and voila. It is so easy and I highly recommend Mark and his product. Tell him Shaun sent you.
As Shaun has said, the replacement decals from Mark at ovenlettering.co.uk seem to be the easiest solution to a common problem. The transfers are easy to apply (there's a "how to do it" intruction video on the website), and also seem fairly robust once on
Lauren, Viking control panels used to have painted lettering and yes it does come off with cleaning and time. It is not a sticker. The new replacement control panels are printed with laser. They are much more clean looking and cant be rubbed off. You'll need to get with your local Viking Certified Servicer and have them order this for you.
SOURCE: Ariston FM22 Oven No Control decals
Go to this site www.appliancepartspros.com and look up your model there and you can order the decals or replacement knobs there.
SOURCE: I have a Viking double
Click this link directly to get full disassembly diagrams.If lower door is closed,then lower unit has to be disassembled,if upper door is got locked,then upper section has to be disassembled. Click this link directly to get section by section disassembly diagrams:--- http://technoanswers.blogspot.com/2011/01/how-to-disassemble-viking-electric.html ------------------ If the diagrams are not very clear then check out this links one by one for proper view:-- Link for control panel:--- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00001.png ------------- Link for door latch:-- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00005.png ---------- Link for door disassembly:--- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00006.png ------------- Link for cabinet disassembly:--- http://c.searspartsdirect.com/lis_png/PLDM/10057060-00002.png -------------------------- This should help.keep updated.Thanks.Helpmech.
SOURCE: The stickers that indicate what
I true wish there was, Viking will sell you only the panel with the writing on it, because its part of the panel. I an sorry that happened but there is not fix to it other than replacement of the panel.
Good Luck
Viking Number to verify if you like
1-888-845-4641
I am a certified servicer
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Unfortunately appliancepartspros don't stick decals for Viking appliances. Has anyone used the services of ovenlettering.com, which is based in the UK?
Thanks Shaun! My other option is to replace the control panel @ $100 so I will determine which option provides the best result and at what price.
I've used overlettering.co.uk and it works great. Much cheaper than a new control panel.
I had a similar problem with my oven and contacted ovenlettering.co.uk who supplied me with excellent quality replacement decals with super fast delivery too
They are SO expensive. Almost $100.00 USD for decals.
