I need to unlock dvd region on my laptop
You can download a region free players on your laptop and region free players can play dvd of any region code. You can try Leawo Blu-ray Player which is a region free player and a free Blu-ray player and DVD player.
Directly follow the guide to unlock the DVD region code. it works good http://drm-assistant.com/dvdtips/how-to-bypass-dvd-region-code.html
Directly follow the guide to unlock the DVD region code. it works goodhttp://drm-assistant.com/dvdtips/how-to-...
SOURCE: DVD region is locked
DVD Drive is not locked power dvd software is lock dvd region install any other dvd playing software it will work...
SOURCE: need to unlock laptop DVD
You can change the region code for your DVD player but not more than 4 times.
There are firnware updates to change DVDs to region free, if you are not carefull you can screw up your DVD drive.
Suggest you install a program to allow you to play any DVDs regardless of which region the DVDs were created for.
Go to www.dvdidle.com for their Region-Free program
SOURCE: need to make laptop notebook packard bell dvd region free locked on o1
You can only change the region code up to 4 times then it locks on the last change.
There are some firmware upgrades that can change the drive to region free, if you can screw it up or put in the wrong frmware upgrade then the DVD drive will be a piece on junk.
I suggest you install a region free software that will allow you to play any region DVDs.
Go to www.dvdidle.com to get their Region-Free software, it is not very expensive.
SOURCE: unlock dvd zones
The region code can only be changed 4 times and it locks on the 4th change.
There may be a firmware upgrade that make your DVD region free, but if you make a mistake or install the wrong firmware upgrade then the DVD will be a piece of junk. You will need to Google search for DVD firmware upgrades for your model DVD.
The best way to view DVDs from other regions is to install a piece of software that defeats the region code. I use a program called DVD-RegionFree from
www.dvdidle.com
There are possibly other programs available, again Google search for them.
