20 Most Recent Toshiba DR410 DVD Recorder Questions & Answers
Try a new / different disk recognized by this recorder. Make sure you're using DVD+RW disks. Others will not be recognized.
Toshiba R410 Specs CNET
Toshiba DR410... | Answered on Feb 25, 2015
0274,0277,0271.
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Toshiba DR410... | Answered on Sep 06, 2014
Did you try plugging it into a different socket before concluding it is dead?
Toshiba DR410... | Answered on Apr 03, 2014
get a new one amd instage it and tell the manger that it is not working
Toshiba DR410... | Answered on Dec 26, 2013
You can play these recordings without finalizing them in the D-R410, but if you want them to play
in other DVD players, they need to be finalized. See pages 28 to 32 in manual. If you want to
finalize the disks you've already made, follow the directions on page 32.
Toshiba DR410... | Answered on Sep 13, 2013
ok let's start from simple connection.we'll use color coding,let's say rca plug. yellow plug is video.from DVD video out is yellow and to the tv is video in. white and red is for audio.if your tv is 5.1 compatible then follow the label on your DVD and insert it to its corresponding label on your tv.then still if your using a separate audio amplifier only the yellow/video plug is used.
Toshiba DR410... | Answered on Jan 26, 2013
It is possible that the disks are not finalized. You may need to configure it to auto finalize, which is off by default. It would be impossible to have more than one title on a disk if you always auto finalized. Check your manual, and finalize your disks. Many times marginal disks will play OK in the unit they were recorded on, but not so well in other players. The media (disks) could be the problem as well. On a side note, the DR410 will NOT burn DL (dual layer) disks. I hope this helps and good luck.
Toshiba DR410... | Answered on Nov 05, 2012
Press Setup on the remote > General Settings (the first option down) > Display (the second option in this list) > OSD Language *the first line) and choose your language (English should be the first in the list). Use the up/down arrows to change lines followed by Enter to select the option.
If you are using a universal remote that doesn't have the setup button that works, you need a different remote. Remotes.com has a new remote almost identical to the one that came with the unit as well as used remotes. http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12832146296260&smodel=DR410&brand_pn=TOSHIBA_DR410 .
I hope this helps.
on the remote is there quick navi button (this will take u to the finalizing screen)
if you can remove the cover of your dvd recorder, then access the power supply board first check if their is bulging capacitor or transformer which emits the noise.if ok, observe if the noise is coming from the dvd burner during recording.
Toshiba DR410... | Answered on Sep 16, 2012
Toshiba DR410 DVD Recorder Logo
81 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
no power dvd pluged in hdmi cable end
  • Televison & Video
