SOURCE: lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
SOURCE: HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
SOURCE: LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
SOURCE: I have an LG side
I have an LG side by side fridge/freezer model GR-L206CVQA.
The display panel locks up and I cannot change the dispenser
