SOURCE: Amana oven and broiler won't fire
Check your stove breakers first. Click them off, leave them off for a minute and put the breaker back on. It sounds like you are having a power supply problem. Make sure to check your potlet and power chord as well.
SOURCE: stove quit working
We had the same problem. But it would turn back on after 20 or so minutes. But as soon as it heated back up to 350 it would shut off completely. I called tech support but only got someone in India who I couldn't understand. Then I called a local technician and they charge a grip just to look at it! I finally got sick of it and banged on the control panel. To my surprise it turned right on and has been working ever since :) *This method is not recommended for use on children or animals.*
SOURCE: Kenmore electric range: oven & broiler will not work.
All your oven features are controlled by the Electronic Range Control (ERC) board. This is your clock/timer assembly. Unfortunately, most do not have fuses and are not serviceable. You will probably need to replace the board. The following link explains how:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
Replacement circuit boards can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. For the model number you have listed, the part number for a new board is 316207511.
NOTE: The overlay, which is the plastic template with the numbers and letters preprinted on it, does not come with the new board. It has to be purchased seperately. However, if the current overly is still in good shape, it can be peeled off the old circuit board and reused. The part number (if required) is 316220841.
If you have questions about this repair, please post back and let me know. I hope this helps you.
SOURCE: Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Testimonial: "100% correct, I ordered the part from on line and it was a very easy fix and the oven is working great. Thank you"
SOURCE: frigidaire model fef336ece.oven and broiler wont
thermostat possible open check not sure if this model has a resettable or not
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
