SOURCE: turbo air freezer
Check the time setting on the defrost timer. It may not be set to the correct number of minutes for defrost. Compare it with the side that is working properly for the right time of the cycle.
SOURCE: LEAKS WATER WHERE WATER LINE GOES INTO FREEZER.
An easier fix is to redo the connection. Turn off the tap the supplies water to refrigerator, should be on your cold water line under the sink. Remove not on the solenoid valve(blue valve) slide the nut further up the vinyl tubing cut the tubing above the old connection. push the tubing into valve and tighten nut finger tight. turn the tap on a little and check for leaks at the solenoid. If no leaks open tap all the way. If leak tighten nut a little more only until leak stops. then turn tap on all the way.
