20 Most Recent
Sub-Zero 19.3 cu. ft. / 547 liter Upright Freezer 601F Questions & Answers
My Sub-Zero 601F Freezer displayed -20 and no
repairs should be performed by a qualified service technician. possible open thermistor in the refrigerator/freezer. the freezer/ thermistor connection may be corroded. check if the evaporator fan motor is running. yes the service technician should check the operation of the refrigerator/freezer.
Door will not stay shut, nothing is blocking it,
1. Check entire condition of seal, even the bottom section and make sure it is not damaged.
2.Check the seal on the side of the door the hinges are on, they may be catching on the cabinet when closing, if so, use petrolium gel and rub it on the face of the seal, this will allow lubrication of the seal.
3.Also check that the seal has not swelled , if so, you can rectify this by using a hair dryer and starting on the sides the hinges are on, carefully heat the outside of the entire seal on that side, then close the door and hold firmly closed till cool, then move to the other side, top, then bottom doing the same process each time, this usually works a treat.
I hope that has been of some help for you and it works.
Please dont forget to vote, thankyou. regards Russ
HOW TO MAKE MORE ENERGY
PLease set your thermostat at middle point. Clean your freezer regularly. Don't leave the door ajar for long time.
My 601 F sub zero
check the cold control first,this is the control you set the temperature by,if the sensor bulb on this control is bad it wont tell the control board to tell the compressor to cycle on and off
Subzero Freezer ice keeps building behind coils
in 601 model. really common problem is the drain hater. watch close the ice maker for a BIG long ice. on the cotton psrt of the back wall. some models have 1 some 2 depends in the serial num. ask you tech for replace the DRAIN TUBE HEATER. that way your cover. really helps a lot the code number...................good luck................. leave a comment...........thanks
Ice maker does not make ice i replaced filter
check the fill tube for ice blockage.some times water will freeze in the tube and stop the water flow.also if the unit has a reset button on the ice make reset it a few times.and if tat does not change any thing check the fill valve and water supply line.last thing too do is replace the ice maker
Freezer always on
If the display reads -20 even though the freezer is set for 00, shut the unit off. If you can still hear the freezer compressor running, the board has a stuck relay for the freezer compressor. You will need a new board.
