Hi, please help me. when browsing suddenly this window name "BE.tmp.exe - application error" the instruction at "0x0040c173" referenced memory at "0x00000004". The memory could not be "read" I didn't install anything, only browsing the internet. please tell me what to do with it
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe
%FontsDir%\nwlnkipx.exe
%FontsDir%\nwlnknb.exe
%FontsDir%\nwlnkspx.exe
%FontsDir%\nwrdr.exe
%FontsDir%\oprghdlr.exe
%FontsDir%\p3.exe
%ProgramFiles%\internet explorer\keymaker.exe
%ProgramFiles%\outlook express\keymaker.exe
%System%\1025\zipfldr.exe
%System%\1028\zipfldr.exe
%System%\1028myztx.exe
%System%\1031\zipfldr.exe
%System%\1033\zipfldr.exe
%System%\1037\zipfldr.exe
%System%\1041\zipfldr.exe
%System%\1042\zipfldr.exe
%System%\1054\zipfldr.exe
%System%\2052\zipfldr.exe
%System%\3076\zipfldr.exe
%System%\3com_dmi\edb.exe
%System%\3com_dmi\edb0000a.exe
%System%\3com_dmi\edb0000b.exe
%System%\3com_dmi\edb0000c.exe
%System%\3com_dmi\edb0000d.exe
%System%\3com_dmi\edb0000e.exe
%System%\3com_dmi\zipfldr.exe
%System%\catroot\zipfldr.exe
%System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe
%System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe
%System%\catroot2\tmp.exe
%System%\catroot2\zipfldr.exe
%System%\com\zipfldr.exe
%System%\dhcp\zipfldr.exe
%System%\directx\zipfldr.exe
%System%\dllcache\zipfldr.exe
%System%\drivers\disdn\ws2ifsl.exe
%System%\drivers\etc\atmlane.com
%System%\drivers\etc\atmuni.com
%System%\drivers\etc\audstub.com
%System%\drivers\etc\battc.com
%System%\drivers\etc\beep.com
%System%\drivers\etc\bridge.com
%System%\drivers\etc\cbidf2k.com
%System%\drivers\etc\ws2ifsl.exe
%System%\drivers\ws2ifsl.exe
%System%\drivers\zipfldr.exe
%System%\export\zipfldr.exe
%System%\grouppolicy\adm\gpt.exe
%System%\grouppolicy\gpt.exe
%System%\grouppolicy\machine\gpt.exe
%System%\grouppolicy\user\gpt.exe
%System%\grouppolicy\zipfldr.exe
%System%\ias\zipfldr.exe
%System%\icsxml\zipfldr.exe
%System%\ime\zipfldr.exe
%System%\inetsrv\zipfldr.exe
%System%\keymaker.exe
%System%\macromed\comadmin.exe
%System%\macromed\comempty.exe
%System%\macromed\comexp.exe
%System%\macromed\edb00017.exe
%System%\macromed\res1.exe
%System%\macromed\res2.exe
%System%\macromed\tmp.exe
%System%\macromed\zipfldr.exe
%System%\microsoft\zipfldr.exe
%System%\msdtc\msdtc.exe
%System%\msdtc\trace\msdtc.exe
%System%\msdtc\zipfldr.exe
%System%\mui\0418\ftdisk.exe
%System%\mui\0418\gm.exe
%System%\mui\0418\gmreadme.exe
%System%\mui\0418\hgfs.exe
%System%\mui\0418\http.exe
%System%\mui\0418\i8042prt.exe
%System%\mui\0418\imapi.exe
%System%\schost.exe
%System%\services32.exe
%System%\spool\drivers\w32x86\3\mouclass.sys
%System%\spool\drivers\w32x86\3\mountmgr.sys
%System%\spool\drivers\w32x86\3\mqac.sys
%System%\spool\drivers\w32x86\3\mrxdav.sys
%System%\spool\drivers\w32x86\3\mrxsmb.sys
%System%\spool\drivers\w32x86\3\msfs.sys
%System%\spool\drivers\w32x86\3\msgpc.sys
%System%\syskey_dll\sysupdate.exe
%System%\system\system.exe
%System%\tmp.exe
%Temp%\5.exe
%Temp%\70554keygen1.exe
%Temp%\guqf296\keymaker.exe
%Temp%\ixp000.tmp\efubtgis.exe
%Temp%\ixp000.tmp\key_gen.exe
%Temp%\ixp000.tmp\keygen.exe
%Temp%\ixp000.tmp\keymaker.exe
%Temp%\ixp000.tmp\tmp.exe
%Temp%\ixp000.tmp\tvonuaek.exe
%Temp%\ixp000.tmp\zwwltphz.exe
%Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
Scan ur pc for virus it look like a virus infection and use good antivirus while surfing internet.
U have 2 solution for it
first install avast antivirus from here
http://www.softpedia.com/get/Antivirus/Avast-Home-Edition.shtml
then install and update it
then scan your computer in boot time
then if it removes all virus and malwarre then your problerm fixedd still u face problem and u want to restore to its previos state u can restore it.
go to start menu then paste this in run
C:\WINDOWS\system32\Restore\rstrui.exe
then follow the procedure
u can restore to its previosa state
also try this
It is a problem with Photoshop.
Version 7 but it sounds like 6 also does this. You can re-install
Photoshop, just don't make it the default program for opening Jpg
and Gif files (during the photoshop installation process, anyway).
After Photshop has been installed, you can go to the file types in
"Folder Options" (under tools at top of all folders) and make it so
Photoshop opens Jpg and Gif files.
Another problem is with Spysweeper.
Disable Spysweeper or even uninstall it and you'll get rid of this
problem. I fought with this issue on a computer a friend had until I
figured that out
