The bobbin case on an Elna SU 62c has 3 loose pieces off. This is the second time in 15 years. I cannot find a good picture to see how it goes back together. Do I have to buy a new assembly? I think I have all the parts. Grammy
See my solution given earlier
http://www.fixya.com/support/t25058310-reinsert_bobbin_race_back_into_elna_su#solution-section
Really you are very appreciated in your machine maintenance. If you wanted to Elna SU 62c machine bobbin case
please see the link :
http://www.ebay.com/bhp/elna-sewing-machine-bobbins .
SOURCE: bobbin casing for elna 8000
There is one small metal piece 3/4 inch long and shaped like the letter "T" that fits under the right hand needle plate snap one screw. Attach to underneath square nut and can be seen sticking out from the top holding the bobbincase in place after the top plate is replaced and everything is back together. If this is not it, a picture would help as I have repair 100's of Elna 5000 to 9000's.
SewTech
SOURCE: thread is getting stuck around bobbin case in
Try turning your bobbin around, it may be facing the wrong way and it will get caught around the bobbin casing. I had that problem until I turned it around, just the bobbin in the case not the case.
SOURCE: how to thread bobbin on Elna SU
if you go to this solution
http://www.fixya.com/support/t1064475-elna_carine_electronic_sewing_machine
you'll see the threading diagram for an Elna SU, threading up is same on all the air electronic Elnas (the SU, TSP, 500, Jubilee and Carinas).
If clicking on the link doesn't work, then just select the text, control C to copy, the paste it into your browser address bar.
Trust this helps.
