Get the 8.00 rca universal remote at wal mart (model rcr312w) follow the auto scan instructions and it will work. I just had this same problem, bought 4 universal remotes and this one worked!
Your Durabrand TV has cousins. You may not see the codes in the universal remote for Durabrand. So in this case you may try three other brands that may operate this TV. You will need a universal remote of course. The following brands to try are, Ilo, Sansui . and Orion. These TVs are all under the same manufacturer. Good Luck and thanks for asking! Show a few hands of support!
It is highly unlikely that if you had the code book that there would be an Ilo code. You have three options:
Option one is to purchase a high end universal remote that has an auto search feature for the correct code, since Ilo is unlikely to be one of the offered codes. Ilo does not build their own tvs, but vends out manufacturing of the sub assemblies and puts their name on it.
Option two is to go online directly to Ilo and purchase the original remote. Be prepared for sticker shock. Original remotes can be expensive.
Option three is use an external tuning system to your tv such as a cable box or vcr which will allow you to change channels remotely using the remote that controls the device. Many cable company boxes have remotes that also control the volume and on/off functions.
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
my dog ate my remote and broke it and i just called an ordered a new remote from the # walmart extended service plan gave me the # is 800-216-5156 they need the model # and or serial # and the remote only cost me 14.99 plus shipping hope that helps!!!
Ilo is made by Orion and/or Sansui.
My Ilo dtv2794B was programmed on Direct TV remote as follows:
In Direct TV mode press 'menu' .
Go to parental ,faves setup
Go to system set up
Go to remote
Go to TV
Select brand (Orion)
Follow directions from this point.
Good Luck>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
