Step 1
Wind your clock once a week by inserting the winding key into each of the three keyholes on the front of the clock and winding until the key won't wind any more. Make sure to wind your Linden clock before attempting to set it.
Step 2
Access the clock hands on your Linden clock by opening the glass door on the front or back of your clock, depending on the model. Use the winding key, if necessary, to unlock the clock's front or back door.
Step 3
Set the time on your Linden clock by moving the clock hands to the appropriate time. The hands of your clock can be moved clockwise or counterclockwise.
Step 4
Locate the chime-selector lever that extends from the opening next to the "3" position on the clock dial.
Step 5
Move the chime-selector lever to "Whitt" for the Whittington chime, "St. Mich" for the St. Michael chime and "West" for the Westminster chime. Set the chime-selector lever to "Silent" if you don't want your Linden clock to chime at the top of every hour.
Check your manual for setting clock in correct time zone (where you live)
Lift gate handle linkage seized, bent or broke(disassemble repair and lube)
security light not blink means it is not armed(lock your doors)
The specific answer will depend on the make and model of your oven. That said, in the majority of systems built recently, there will be a button labeled [Clock]. Press it, possibly for several seconds, and the clock display will blink. Enter the time with the keypad. If there is usually AM/PM, try either pressing an AM/PM key, if there is one, or the [ENTER] key, to toggle. Then Press [Clock] Again. That will likely do it.
It is impossible to give you accurate directions without knowing the brand and model number. However, most microwaves will have a "clock" or "Time of Day" button. Push it, then punch in the numbers for whatever the current time may be. Now, with some models, you press "clock" one more time, and with others, after keying in the time of day, you just wait, and then the time starts ticking.
Re: Eddie Bauer Wireless Thermo Clock - Model 0465
TIME ZONE SETTING
The default time zone is PACIFIC (P). lf your location is not in the Pacific zone, set the time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln alarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern.
4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit automatically 30 seconds later without pressing any key.
This sequence fixes my thermo clock. Follow step-by-step ......
Press the Clock Set button on the top of the clock radio. Press either the forward or reverse (skip) buttons to change the time. Press and hold the button to get the time to change faster. Make sure the AM/PM indicator is correct for the current time. Then press Clock Set or wait 5 seconds without pressing a key to exit the time set mode.
You set the alarm time similarly after pressing Wake Time. Make sure the Wake Mode is set to alarm, radio or CD.
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
