Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
Yes , the element is easy to replace
Remove the cover at the rear of the oven, there you will see the element, undo the screws securing it, and replace the element.
This should solve your prob.
Good luck..
two hidden levers on end of hinges. When raised, door able to be re-inserted or completely detached. very simple once i discovered levers on the hinges.
