Coils keep burning out on 12.5 hp briggs & stratton small eng. Eng on snapper riding mower ,runs good till coil goes bad for about 2-3 hrs
Must replace coil but must install KIT#192931 (to ignition harness) to prevent voltage surge to coil when turning off ignition . the surge burns out the transistor in coil. kit will correct this surge.
Hello:
>>Have you Replaced the Coil with a New One?
>>If No, then Replace the COil and your Problem will be Corrected. The Ign Mosule inside the Coil is Heating Up and Shorting Out. This Causes the No Fire when Hot Problem.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Is the coil going bad after 2 or 3 hours since replacing it?
