I have a Frigidaire Electric stove and when I turn on the burners the two lights will not light up and all four burners will not work.
I have replaced the fuses above but this has not solved the problem.
If I turn on the oven the burners will start to work.. they won't get red hot but they do get hot. Once the oven reaches the sleected degrees and shuts down then the burners do not work any longer so you have to keep the oven on low and the door open so it is consistenly kicking in to heat up and then the burners will work but not on high.
The one outlet on the top of the stove works.
Is there a fuse that contols ech element
Same here, lights wont go one, elements wont get red hot, clock not on... is it a 220 V problem?
Frigidaire electric oven
