Trying to program remote for sony tv
295,299,290,291. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
SOURCE: codes
Magnavox 0054, 0706, 0030, 1454, 1254
Sony 0000, 1232
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
SOURCE: code for Sony projection tv
download the user guide from here:
save in your computer.. and you get the code for sony projection tv
http://safemanuals.com/user-guide-instructions-owner-manual/ONE%20FOR%20ALL/URC%203021-_E
SOURCE: I NEED A PROGRAM CODE FOR A DISNEY TV
I had the same problem I used code 10463 and it worked...My daughter has a Disney Princess TV model DT1350P. Hope this helps.
