The digital to analog converters did not exist when the TV was built and the remote programmed. Thus you will have more luck programming the converter box's remote to control the TV. (At least with my converter box, the included remote could only turn on and off the TV. It would only change channels on the converter.)
Most universal remotes only have codes for devices released 6 months or more before the TV was programmed. So a new universal remote will probably control both the TV and the converter box. (Program the converter box using a code for LG or Zenith set top boxes if Insignia isn't listed. LG makes Insignia video products for Best Buy.) The remotes that are programmable by a USB connection to a computer are the fastest to set up.
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
doublecheck the paperwork for both the converter box and the universal remote. the universal may be too old to be used with your converter. look in the back of the universal's manual to see if your box's corporation has a code you can set.
I have the Phillips Universal Remote (model#SRU4208WM) and I have the Insignia digital converter box (model#NS-DXA1-APT). The code was 0267. The Insignia converter box is the one the government grants work for.
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
