Possibly the power outage caused your modem to reset. The wired connection would still work. first thing I would try is to reset the modem with the reset button, login to the management console and put in your network name and password again.
Dis-connect the plug from the wall receptical and other leads attached to to the unit. Next press and hold power for too minutes in an attempt to reset the microprocessor, now hook everything back up and power on, if this fails it probably would be cheaper to replace the combo than have it repaired.
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
Your laptop see's the router, but the problem lies between the router and the modem.
Try the following tasks in order:
1) Unplug the power to the router
2) Unplug the power to the modem (the black box that the router is networked to)
3) Wait 10 seconds.
4) Plug the power back into the modem
5) Plug the power back into the router.
This should solve the problem! If this was helpful then please give me a good rating, thanks!
Tries unplug,replug an hour later,let the tv reset itself back to factory setting.After,turn on the tv,go to the menu,go to sound on ur menu go down to reset the sound.The functions should go back to normal,not than.Ur tv Tuner signal board have a short,in the power outage occurance.
I have experienced the same issue with belkin routers. First, test your laptop with other wireless connections {e.g. Starbucks, McDonalds, etc..} to see if your laptop's wireless adapter is working okay. If so then it sounds like your Belkin Router needs to be reset to the factory defaults and then your personal wireless network settings re-entered.
You definitely need a tech. Since your power outage you may have a problem with your compressor which when there is a power outage can damage the compressor from what is called a brown out. A brown out happens just before the power goes out and because of low voltage to the compressor can burn the windings causing it to either burn out or become very noisy. CALL someone soon and I wouldn't tell them about the power outage as they may not fix it under warranty. If for some reason they find out sometimes the power company will pick up the tab. Good luck.
