I think it is a electrical problem because the wall switch (GFIC) goes off and the outlets on that side wall and back wall do not work when that happens.
SOURCE: wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches. It sounds like the Electrician set up the junction box for two circuits(Lights and Fans). i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
SOURCE: Ceiling fan lights do not work
You may have shorted out the light kit. Did you remove the other bulbs and put in new ones? They may have all blown when you heard the noise. Try that first, and if it still doesn't work, you may have to buy a new light kit. They are not expensive, and you can buy one without the glass bulb holders or cans, whatever you have. Then you can still use yours after you install the new light kit. Good luck!
SOURCE: Remote control ceiling fan
I am changing the remote in hunter fan an i got the wires mixed up coming from the fan what wire goes where?
SOURCE: ceiling fan and light wiring, 2 switches, 1 romexHunt
If you have only one black and one white in the ceiling to connect the fan / light to , then you have only one switch for this ceiling box. The fan / light will connect the white wires together and then the two colored wires on the fan to the black ceiling wire. In order to use separate switches for the fan and the lighht a 4 wire cable must go from the switches to the light so you have a red and black wire to switch the two separately .
SOURCE: Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
