SOURCE: how to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
SOURCE: I have a Nixon LowDown
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
SOURCE: my nixon lowdown watch screen
Hi
You don't fix it. Hopefully you mean it's only 3 days old from being new and you can take back to the shop for refund/replacement.
ROM - stands for Read Only Memory and is basically the chip that all the software and information is stored on. This runs the watch and it's this that has failed. You could try reseting the watch by removing the battery and then replacing it.
SOURCE: User Manual Nixon Lodown Tide Watch
I need to know how to activate and disactivate the mode of energy saving.
