DVD no signal HDMI
Loose or crack or cold solder joint holding the socket of HDMI.Cold solder issues - each component is soldered into small
holes on the printed circuit board which in turn connects said component to the
other components. Due to time, heat, use, some solder joints would be cracked
or loose. It is possible that the cold solder is still minimally connected
(hanging by a thread). When the TV turns on heat would be generated which would
be sufficient to further loosen up the solder joint to the point it no longer
provides electrical contact. Jarring the unit creates movement inside enough to
re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly
probable that there are no defective components. As you have surmised, it is
possibly a loose connection, solder joints are "connections"
except that molten soldering lead is used to attach/connect the component to
the board, "loose connection" in this sense is equal to "cold
solder".
Again on the assumption of no defective parts, then seeking a more experienced
buddy for the soldering might be to your advantage. This is of course in
addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Good luck;
