20 Most Recent Yamaha RXV371 Questions & Answers
I bought YamahaRXV375 online. Can anyone help with firmware?
google it sometimes if you input the model number and name, it will come up with what you need to repair it
3/9/2015 10:28:52 PM • Yamaha RXV371 • Answered on Mar 09, 2015
0answers
I hooked up my wii on av1 with a component cable with audio on audio 1 and i have sound but no picture.
If I am reading this right, you are only hooking up one cable for audio. There is another cable needed for video. This jack is normally color coded yellow and labeled video out/in. You can use your audio cable to try this and then you will picture but no audio.
2/17/2014 2:19:43 AM • Yamaha RXV371 • Answered on Feb 17, 2014
It wont turn on, checked the fuse thats ok
If it doesn't do anything after you press the power button, there is probably some faulty component (like capacitor or diode) in the power input circuit inside the receiver. Send it to the local repair shop, it shouldn't be hard to fix it.
10/21/2013 12:50:12 PM • Yamaha RXV371 • Answered on Oct 21, 2013
0answers
Back feed
Be the first to answer 2/4/2013 11:55:00 PM • Yamaha RXV371 • Posted on Feb 04, 2013Be the first to answer
Can I connect my computer subwoofer to my Yamaha A/V receiver
Yes if it has a suitable speaker connection available and is nominally 8 ohms impedance Speaker and AV.
4/15/2024 11:25:42 PM • Yamaha Audio... • Answered 5 hours ago
I have a Yamaha RX-V640 audio amplifier and I have a problem with opening. when I open it after half a second it closes
Check power cycle,check connections,seek professional repair,check overheating and test with diff?rent outputs/inputs
4/15/2024 5:34:38 AM • Yamaha Audio... • Answered 23 hours ago
Why does my Yamaha HTR-6130 power down after 3 seconds?
Overheating,faulty connections,power supply issue,faulty components,protection
4/15/2024 5:19:14 AM • Yamaha Audio... • Answered 23 hours ago
Yamaha M-60 Power Amplifier distortion and sound goes off sometimes
Being from 1985 or there abouts, it probably needs some TLC at a Yamaha service centre. May need new capacitors and resolder dry joints for age related issues.
4/1/2024 7:26:20 AM • Yamaha Audio... • Answered on Apr 01, 2024
Jerky sound in one channel Yamaha M-60 Power Amplifier
WD-40 ... Very dangerous as it not only flammable when wet but is bad for electrical contacts as it leaves a residue behind that does not conduct electricity very well. Check speaker connections first.
4/1/2024 7:22:45 AM • Yamaha Audio... • Answered on Apr 01, 2024
Yamaha rx-v671 usb overload issue
(francais) hello in my issue the probleme was a little resistor r027 it's in this red zone and very ugly. easy to find. a friend was unsolded the resistor and weld a little wire after wash with isopropanole alcool. the resistor test the tension when we plug usb thing. less the resistor the usb ports don't work. you can buy r027 for 2 euros for 100 pieces.... or 2 euros for 5 10 pieces (funny). ampli r027-w2gpcyn2rttv51s5zcrlhnl2-d-0.png
3/5/2024 10:05:15 PM • Yamaha Audio... • Answered on Mar 05, 2024
RX-V6A - Zone 2 Speakers do not give sound
Follow the procedure as given in following link. RX-V6A ' ENJOYING IN MULTIPLE ROOMS (ZONES) (yamaha.com)
12/14/2023 12:29:06 PM • Yamaha Audio... • Answered on Dec 14, 2023
Yamaha YST-FSW050 Ultra-compact powered subwoofer. It has bad vibration between 30-50 hz?
Question edited for clarity, full make model (what it is)'. Question moved to Yamaha Audio. It may be sympathetic vibration and is coming from something nearby. Put it on a folded towel or sit in the floor to test it. https://www.google.com/search?q=YST-FSW050+bad+vibration ..
12/9/2023 7:36:22 PM • Yamaha Audio... • Answered on Dec 09, 2023
How do I reset YAMAHA RX-V6A protection mode?
You must repair the amplifier first. Take it to an authorised Yamaha service centre.
12/6/2023 5:49:26 PM • Yamaha Audio... • Answered on Dec 06, 2023
Yamaha HTR-5750/5740. My Subwoofer not broadcasting
Visit 00_HTR-5750_U_EN.book (yamaha.com) and see page 59 (Troubleshooting).
9/23/2023 11:27:47 AM • Yamaha Audio... • Answered on Sep 23, 2023
Yamaha RXV371 Logo
12 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
bought yamaharxv375 online anyone help
  • Audio Players & Recorders
